2004-07-24 06:54 PM
2004-07-30 08:49 PM
Ferenc wrote:I have been able to use the SU plugin with no problems using your method. It is just that sometimes when working on an idea for a client I work on SU and when I switch to AC I just use the SU model as a reference, so exporting only the 2d info is enough. But that is the way I work the design developement phase of projects because it forces me to re-evaluate the decisions made in the schematic phase.
I just felt that retracing because you didn't get the expected result first time is little awkward as opposed to use some layers, groups or components to remove the clutter, but have your walls, floors, roofs, windows in place, components converted into library parts....
From surface model to solid building elements...
Ferenc wrote:I'm in total agreement on this point
I wouldn't recommend drawing hatched areas and lines for representing walls in ArchiCAD, but anybody is free to do so and post about it.
2004-08-02 12:16 AM
