View specific floor plan cut planes
I'm setting up a few different sets of plan views and want to be able to set different cut planes for them. I only know how to do them globally through Document > Floor plan cut plane but this changes the cut plane on all the floor plans in my project. Is there a way to have a cut plane specific to a certain view, say 'ground floor proposed plan' but then have a different one for 'ground floor existing plan'?
Thanks
Sure aditi.
Select the specific Plan ViewMap > Settings > Click the FPCP (Floor Plan Cut Plan) Settings button.
Here:
Sure aditi.
Here:
Great, thank you!
