View story below & above on 13 Version
How do I view ghost story above rather than just below when I'm working on a floor plan.
I know how to do it in Version 9. Which was very helpful to check alignments. Version 13 changed this - can't find menu.
Bob
Trace Reference is what you're after. You can use a Layout, View from view map, or story from the project map, easiest way is to right-click on the relevant view and use the "show as trace reference" option. There are also options to show story above or below current, or use previous story. Not sure where in the menu structure Trace Reference is in AC13, but in 15 it is in the View menu.
HTH
Now I'm a happy archicad user...thanks!
