ā2007-06-04 08:39 PM
ā2007-06-07 12:29 PM
ā2007-06-07 12:39 PM
ā2007-06-07 04:00 PM
ā2007-06-07 04:30 PM
ā2007-06-07 04:51 PM
ā2007-06-07 05:01 PM
Braza wrote:From what I can tell from your posted image, you'd need control joints in those two locations anyway, so actually the model is accurate!
Can we call this a bug?
ā2007-06-07 05:03 PM
ā2007-06-07 10:54 PM
Braza wrote:Yes we can.
Laura wrote:Say what? In typical construction there is no reason to believe that the cladding will join where your wall do within ArchiCAD. A control joint is a thing. It has a dimension. If you want one, add one, exactly where you want it, but don't force me to have one. This is a line, a graphic problem, a bug.
ā2007-06-07 11:03 PM
Geoff wrote:No, but it is good practice to locate control joints at changes in wall height, although I've seen a lot of (typically residential) construction that disregards this practice. Also will depend on what type of cladding is being used...
ā2007-06-07 11:26 PM
