‎2006-10-17 06:53 PM
‎2006-10-17 09:32 PM
‎2006-10-18 06:44 AM
‎2006-10-18 07:25 AM
LINZ wrote:it should automatically change its display to match the wall to which it's attached . . . mine do
currently, i have my walls set to display contour lines only in plan. however, i can find no equivalent setting for wall end objects.
‎2006-10-19 05:32 AM
~/archiben wrote:I am using the "wrapped end".LINZ wrote:it should automatically change its display to match the wall to which it's attached . . . mine do :?
which wall-end object are you using?
~/archiben
‎2006-10-19 05:42 AM
LINZ wrote:hi linz
so far, i havent had any luck.
‎2006-10-19 06:30 AM
‎2006-10-19 06:50 AM
LINZ wrote:... but what about the wall end's
my view settings are set to show wall contours only... i'll double check those settings.... thanks for the advice
