Wall End Tool - Materials
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2006-10-17 06:53 PM
‎2006-10-17
06:53 PM
When I insert the wall end, the materials are not matching the existing wall.
7 REPLIES 7
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-10-17 09:32 PM
‎2006-10-17
09:32 PM
Wall ends are library parts which have their materials defined in the GDL script. The can use the walls materials but not all do. There should be a parameter for this in the dialog. Try looking under "3D Representation".
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-10-18 06:44 AM
‎2006-10-18
06:44 AM
thank you!
my next question is -
is it possible to set the wall end 'model view options', to match the wall to which it is attached?
currently, i have my walls set to display contour lines only in plan. however, i can find no equivalent setting for wall end objects.
any advice?
thanks in advance.
any advice?
thanks in advance.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-10-18 07:25 AM
‎2006-10-18
07:25 AM
LINZ wrote:it should automatically change its display to match the wall to which it's attached . . . mine do
which wall-end object are you using?
~/archiben
b e n f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-10-19 05:32 AM
‎2006-10-19
05:32 AM
~/archiben wrote:I am using the "wrapped end".LINZ wrote:it should automatically change its display to match the wall to which it's attached . . . mine do :?
~/archiben
so far, i havent had any luck.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-10-19 05:42 AM
‎2006-10-19
05:42 AM
LINZ wrote:hi linz
i was using 'returned end', but i swapped it out for the 'wrapped end' to see what happened: i still get the wall contours behaving as i'd would want and expect them to based on the model view options.
what are your 2D Representation Settings? mine are in the screenshot below. does that make a difference?
~/archiben
b e n f r o s t
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-10-19 06:30 AM
‎2006-10-19
06:30 AM
for some reason, i can't view your attachment...
my view settings are set to show wall contours only... i'll double check those settings.... thanks for the advice
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2006-10-19 06:50 AM
‎2006-10-19
06:50 AM
LINZ wrote:... but what about the wall end's
i have...
'Use Walls Contour Pen' - On;
'Skin's Parameters' - Automatic;
'Always Draw Contours Line' - Off.
any good?
~/archiben
b e n f r o s t
