Wall Reference lines color
This is an odd one for me. The wall/beam reference lines in my walls have changed to the wall line color so I cant see them when I turn on the ref. line button. How can I change this back to the default black? I have searched the forum and help files but could find nothing. Any help much appreciated...
Thanks.
2 REPLIES 2
David Maudlin
Paul:
The Reference Line Pen is the same pen as the Wall's Cut Line Pen. If you are using a Composite Structure, then you need to uncheck Apply Structure's Settings to change this pen.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
Thank you very much. Somehow as I was putting the wall together I changed that line color. Thanks for the tip!!
