Wall and Column
Dear guys:
I got urgent question, refer to image; can anyone help me the figure out the lines. (they not same line weight when column and wall touch together)
I would like to have same line weight ><,
please help!!
best,
8 Replies 8
Anyone can help? please ! I am urgent
Anyone knows please help, please!!!
best thanks!
right click on the wall, Display Order / Bring forward
Nando Mogollon
Director @ BuilDigital
[email protected]
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Eduardo Rolon
Check that your display settings are set to "True Line Weight" though I cannot make my columns do that.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Tried already, cannot solve.....
AC17 sometimes really makes me headache
David Maudlin
imxxx:
I can reproduce this when the 2 elements have the same Display Order, moving the Wall higher in the order solves it here. Or putting the elements on layers with different Layer Intersection Groups.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dear David:
Still cannot solve it.
There is another problem also urgent:
Please see the attachment, when I add door in wall, there is no problem in PLAN, but lines get disordered and wall have triple line,
Please help me!
thanks
Eduardo Rolon
Looks like you are using "composites" for the walls. If so you need to edit the line weights in the Composite window.
AC29 US/INT -> AC08
