2021-07-27 11:28 AM - last edited on 2023-05-19 10:36 PM by Gordana Radonic
2021-08-06 08:51 AM
Erwin wrote:That's what I did end up doing for these tile finish. I agree the method is the best we have now to make sure all's BIM and quantified. The goodie is great for skirting and corniche tho as it is associated to the wall (move with the wall) and read all openings so you don't need to maintain these. Once I got my GDL skills upgraded i'll try to code an object based on that goodie in term of functionality (associated to the wall, reading openings) but that also allow the texture alignment and the use of material/surface. This way we could schedule it exactly as you do for the finishes with a wall! I'll be happy to share that when I find the time to get it done!
If we were to model this as part of composite/complex profile we run in to problems with classification and it starts becoming a pain in the behind to properly dimension things before finishes are applied (which the contractor would like to know).
For these two reasons we would model it seperately, if needed. I can recommend putting the finishes on seperate layers with their own unique intersection number. This way you avoid unwanted wall connections.
We typically do not model plaster finishes, since the thickness will vary. For quantity take off for price estimates we need m² anyways, so to model the thickness is of little importance to us.
It gets a bit fiddly with doors, as pointed out, but for tile or wood finishes it can be worth it. For some renovation projects we do sometimes model the plaster, when it is covering old brickwork, for example.
For quantity take off, zones offer a lot of options too, but this might be tied to the local version of our zone stamps that are part of the Dutch subscription library.
Properties are very powerful as well for scheduling purposes.
kmitotk wrote:Good to know that trick indeed. It seems that in Australia they have different ways of calculating GFAs NSA/NLA, sometime internal face, sometime external face of the walls, and mid wall for party walls.. But with a bit of workaround I'm sure we can get the same workflow! Thanks for sharing the trick mate.
Great.
Problem is that the extend of zones depend from one place to another depending of the methods of calculation, and here in Melb they usually extend to external face of the walls or mid-wall for party walls.Zones normally extend to the mid-wall here in Japan as well, but rarely to the outer face though. When you place a zone, don't draw it manually but always use the reference line based method. The magic wand should pick up the wall outlines instead of the wall reference lines and the zone area calc will be based on the wall reference lines. And in case some of the surrounding walls can't intersect with one another and the zone won't detect the enclosed area, use a polyline to connect the wall ends to close the gap. Make a separate layer for the polyline so you can hide them on the floor plan. Hope it helps.
