Wall corners
My wall consists of two different materials . but the junction of the two wals does not have a clear border . one of them has a 45 degree corner . it is making the drafting wrong . any solution ? I have attached the photo .
You can place them on two different layers with different layer intersection numbers or use construction material editor to change their priority. If memory serves me well.
If they are generic you can use the junction order for each wall to modify it as needed. Give the black wall low number (like 1) and the other walls higher number (say 5).
Post moved to 'Working in Archicad'
Or probably align the two horizontal walls reference line in the bottom
