Wall intersections
I have some problems with the wall intersections : the priorities works in 2D but in 3D the result is pretty bad. So how can I do a "L" connection in 3D like in 2D ?
Thank you !
Bérengère
16 Replies 16
Is this what you was looking for?
Absolutely !
Whilst in 3D view, i selected the bottom right node and simply dragged it up to meet with the white wall.
Hope this image can explain it.
I tried it but the wall move...
Which version of Archicad are you using?
Also have you got both of the walls selected?
I am using archicad 14, and I select only one wall. But perhaps there is no "automatic solution" to do that...?
What do you mean by the wall moves? the opposite wall?
Maybe you should put in a layer with a different group number.
Like the pict, so they do not intersect.
Marcus Scott : by "the wall moves" I mean when you drag the hotspot, all the wall move, not only the point, and the wall become too long.
Cartann : I thought about that too, but it takes a lot of time (and a lot of layers !) for all a building...
Nevertheless thank you for your answers
