Wall problem
Hello everybody!
I am trying to figure out how to extend a concrete wall to the first red line. The concrete hatch needs to be over the insulation hatch. The concrete wall has to ignore the facade wall and end just end in the middle of the composite wall.
Lingwisyer
Guru
I'm assuming the exterior wall is a composite. If the concrete Building Material has a higher Intersection Priority than the insulation but lower than your facade surface, it should clip one and not the other.
Ling.
