Wall texture in elevation
Hello -
I have run into a composite wall that will not render as I expected in elevation. I have a gyp. board | batt insulation | random stipple combination. No matter how I change the composites / materials / use or not use the elements colors or pens the "batt insulation" fill always shows as the exterior wall treatment. The 3D views have the materials correctly rendered. I have been beating my head against the wall for about an hour over this now. Any and all help is appreciated.
Best regards - Chris
ArchiCAD 9.0
2 REPLIES 2
Djordje
Go to the settings of the material applied and check the 3D hatch associated with it.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks -
I did what you suggested and it did not work so I did what I probably should have done first....reboot. The need to reboot is the only free perk from M$.
Once again thanks - Chris
