Karol Lozinski
Wall transition
Hey guys, can I make a smooth transition between those two walls (insulations)? Or do I have to do it using fills? I've also attached a photo of what I'd like to achieve. Please, excuse me this probably obvious question, I'm just a beginner I'm using ArchiCAD 19.
http://imgur.com/a/I2Ymr
AC 28 Win 11
rgarand
Make sure your "Intersection Priority" (within your "Building Materials") is set to a higher number for the material you want to clean up. See attached
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
