Wall under stairs
I was wondering if there was a way to make a wall under a staircase that is cut at an angle that follows the stairs instead of being a full height wall that ruins the open view that I had in mind.
4 Replies 4
You want to look at Solid Element Operations (SEO) with the wall as the target and the stair as the operator.
Then subtract with downward extrusion.
Stress Co_
......or upwards extrusion
Marc Corney, Architect
Red Canoe Architecture, P. A.
Woops - my bad.
Obviously wasn't thinking that day.
Stress Co_
You were probably distracted by your pet monkey twins.
