Walls missing in 2D
I'm still working with AC10 and I ran into a problem I can't solve.
The walls I drew earlier are still in place, but when I try to place new walls they won't show up in 2D. They show up in 3D though.
What do I need to do?
3 REPLIES 3
Hi Ulla,
I suspect the new walls are either above or below the Floor Plan Cut Plane (FPCP).
In the 3d window select the problem walls, bring up the walls settings dialog box and change the floorplan display to either 'Symbolic Cut', 'Outline' or 'Overhead'. This will force them to display on plan regardless of where the FPCP intersects.
It is also worth double checking the FPCP is at the correct level, as this is stored with each plan View, and can change when you switch between them.
Hope that helps!
Thank you Peter!
That solved my problem.
Thank you solved my problem too.
Much appreciated
