Walls not connecting
Gabriel Cristea
Hi, any idea why any of my walls won't intersect?
- they are on the same layer
- the layer intersection number is the same and it's not 0
- the reference lines are connecting
- the auto intersection is turned on in Options
- the "clean wall and beam intersections" setting is turned on
Operating system used: Windows 10
Lee Hankins
They’ve not accidentally been placed within different Design Options or Renovation Filters have they?
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
6 REPLIES 6
Ricardo Lopez
Hi @Gabriel Cristea
Turn on Clean Wall & Beam Intersections at View> On-Screen View Options.
Regards. -
M. Arch. Ricardo López
it is on, it's one of the bullet points I marked in the original post
You are right. Sorry.
archjcl
It happened to me today as well, the walls were connected earlier, as I worked on the landscaping and noticed all walls were disconnected, no matter what I do they don't connect anymore.
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
No, I literally take the wall tool and draw some chained walls and they come out like that, so they are continous, on the same layer, same everything.
You were partially right that switching rennovation filter fixed it. Don't get me wrong, I just switched from Existing Plan to Demolished then that fixed it. However, even switching back to Existing still keeps them fixed so it's not something wrong in the Existing Plan that was causing it...no clue what caused that but that seems to have done the job. Thanks.
Setup info provided by author
