2008-02-12 07:36 PM - last edited on 2023-05-25 06:12 PM by Rubia Torres
2008-02-13 02:08 AM
2008-02-13 02:38 AM
2008-02-13 03:21 AM
2008-02-13 04:13 AM
My guess is that you have a door/window that extends out of the boundary of a wall or you have duplicate walls on top of each other.Thanks for the suggestions, however...
2008-02-13 05:02 AM
2008-02-13 08:08 PM
2008-02-13 08:40 PM
2008-02-13 09:43 PM
Fixing the wa_trim_us_10 macro will not fix the wa_frame_us_10 macro.Thank you for the clarification. One of the things I love about this forum is the availability of expertise.
I referred you to that to give you an idea about what was causing errors in the wa_frame_us_10 macro.
I am unfamiliar with the door-swing-on-the-wrong-side-of-the-wall issue.This is the one where the door swing does not appear on the side of the wall that is referenced by clicking. I've seen it pop up occasionally in this forum, and it still remains one of the maddening issues for me (since version 9, I think).
To create a .lcf go to file-> libraries and objects->create a container.I tried this but I get a scratch file. I also have no opportunity to specify content, or is the content whatever happens to be in the project file?
Again, I suspect that you are getting errors in the file wa_frame_us_10I've tried to check individual library part types with no luck, unless rough opening dimensions count. Thanks again for your guidance.
because you have set some dimension value for the frame to zero .
2008-02-13 10:21 PM
