2006-11-07
08:04 PM
2023-05-23
03:24 PM
Rubia Torres
2006-11-07 08:37 PM
Rodrigo wrote:You don't want to copy the mesh, lower the copy, SEO subtract it from the original to create the profile to the underside? Still remains solid, still SEO trims walls etc.
I want to build a waved/curved roof: it must work like a mesh because all points must be individually editable, and, at the same time, like a roof because I have to trim walls and slabs to it and the lower surface must follow the upper. Besides it must be solid: two bidimensional meshes with 0,30m elevation difference won't do...
I can't build a profile and extrude it because the roof is also complex in plan. I attach an image for you to see.
Thanks for your help.
[/img]
2006-11-07 08:37 PM
2006-11-07 09:04 PM
Rodrigo wrote:it's already been pointed out that the double subtraction of meshes and SEO will give you what you want, but if you still really want to use roofs (for automatic skylight placement maybe?) you can use the 'Mesh to Roof' command . . . it's a downloadable add-on: go to your help menu and choose 'Archicad 10 Goodies'. you'll be taken to the goodies webpage . . .
2006-11-07 09:40 PM
2006-11-07 09:53 PM
Peter wrote:no idea! the only time i used it was only experimentation. i just thought that rodrigo should know all of the options.
Have these problems been corrected in the latest version of the add-on ?
2006-11-08 02:12 PM
s2art wrote:I have tried that: the upper mesh is the target, the lower mesh is the operator, and I do a subtraction. I have tried with and without lower extrusion, but it doesn't seem to work. The upper mesh doesn't react to it and everything stays the same. I guess I must be doing something wrong...Rodrigo wrote:You don't want to copy the mesh, lower the copy, SEO subtract it from the original to create the profile to the underside? Still remains solid, still SEO trims walls etc.
[/img]
2006-11-08 04:18 PM
