Foti
Weird roof projection
Hello
Was cleaning up my model and I kept noticing some weird volumes that I couldn't select, finally found the source, but i have never seen this before. I use the roof tool to make the roofs, I didn't notice this before but it seems the roof projects the perimeter volume down pasted the editing plane. Ill attach a video and some images.
Foti B.
AC25
PC Precison 5760, Xeon 11955, 64GB, Nvidia RTX A3000
1 Solution
That looks like you have the trimming bodies turned on.
It is an on-screen view option.
It will affect only what you see on screen, not any outputs (prints).
Go to post
3 Replies 3
Foti
That was a rookie mistake, 😞 not even sure when or how I may have turned it on. What would be the purpose of that projected body?
Foti B.
AC25
So you can see what will or won't be affected when you use the 'Connection > Trim' option to trim walls to the roof.
Only the part of the walls inside that cutting body will be affected.
