When to use Absolute Display Limit?
Mats_Knutsson
I'm scratching my head about Absolute Display Limit. I what situation is it the proper method? I can understand what it does but I don't know when to use it?
Mats
AC 25 SWE Full
1 REPLY 1
Shaun Coomber
The "absolute display limit" setting should be used to restrict the display of multi-storey elements above a set height. For example, to show a tower only above a cut to avoid showing the substructure, or to show a roof terrace above a garage level.
Shaun Coomber
Technical Support Team
Budapest, Hungary
archicadwiki - the ArchiCAD knowledge base
