ā2006-08-02
09:28 PM
ā2023-05-23
03:27 PM
Rubia Torres
HOW TO USE "Accessories" ADD-ON?
First, select an existing building element (wall, roof or slab) on the Floor Plan, and then choose the appropriate command from the Design > Design Extras > Accessories hierarchical menu.
The Choose Accessory Object dialog box prompts you to select an Accessory object. Set the object's parameters on the Parameters and Custom Settings panels. Other parameters (for example, the slope of a roof) will be set automatically when placing the object, based on the settings of the associated building element. Click OK in the Accessory Object dialog box, then click on the Floor Plan to place the Accessory Object.
ā2006-08-02 09:38 PM
ā2006-08-02 11:15 PM
