Where is the Wall accessories (molding) in ArchiCAD 11
I have earlier used ArchiCAD 9 and used the Wall Accessories a lot to do base and crown molding for my 3D images. I can't find it in ArchiCAD 11, is it gone? Is it anything else I can use that give the same result?
It is a separate 'goodie' download since 10. Go to your Help menu, Goodies...
One of the forum moderators
Thanks I have downloaded the file and copyed it into the Add-Ons folder but it dosen't work When I restart ArchiCAD it seems to be loaded because it's active in the Add-On manager and I choose it in the Design Extra menu, but when the Wall Accessories window pops up it's emty Anyone had the same problem?
Make sure you download both the Addon and the Library (i believe it is at the bottom of the page). Also make sure that the Library is loaded into the active list. If you place it in the Archicad Library 11 folder then when you start archicad it will load automatically.
