2003-11-27 09:29 AM
2003-12-09 02:09 AM
Can a Revit user create similarly parametric (and thus geometrically changing) objects?Yes.
2003-12-09 04:33 AM
Bill wrote:Bill,
I am truly sorry, but I did not post that reply in manner that was meant to be less than truthful or misleading, or to provided you with the oportunity to springboard into a discourse that led away from my understanding of the thread.
2003-12-09 05:06 PM
2003-12-10 08:03 PM
2003-12-31 08:34 PM
2004-03-13 06:26 PM
Revit users can create their own library objects by using templates designed for this purpose. 3D modelling and 2D graphics (if desired) can be combined together with parametric dimensions and other parameters (e.g. materials for rendering). You don't need any programming knowledge, though I often have to spend several hours with new users before they get the hang of creating these new objects. It's not hard: it's just a completely new experience for most people. These objects are fully parametric and can employ formulae, e.g. width = 2 x height, or window top angle = arctan (roof slope). Arrays can be built into the object, so that a louvered grille can automatically add louvers as needed if the grille object gets taller. Families are major benefit of Revit over AC.For information only, not intended to be a "look why software x is better than y":
2004-03-13 06:45 PM
Toward the end of the process so many relationships exist that the model manipulates things that are locked together from early conditions that getting the last changes is a real problem, i.e. moving something that should not move as it is conditioned to be attached to something that has to be moved.In Revit, you have the ability to 'lock' objects that require relationships or not lock others. Not everything has to be tied together. User input actually determines what is or is not conditional. Beyond that, constraints can be 'broken' if necessary. The move tool has 'disjoin' function to prevent 'moving something that should not move' if you have applied constraints.
The biggest difficulty is Autodesk itself - they just do not give a hoot about an individual user.This is simply not the case with Revit. The Revit Development team has remained separated from the rest of Autodesk. They have very close personal commitment to the individual user. I have had the founders of Revit come to my office to get a better understanding of how I work. That's personal commitment! At the Zoogdesign forums, you will see many of the Revit staff regularly contributing. They rely on our communications with them through the forums and other means to continually improve the product.
2004-03-13 06:55 PM
Scott wrote:Very non-Autodesk like! And very commendable.The biggest difficulty is Autodesk itself - they just do not give a hoot about an individual user.This is simply not the case with Revit. The Revit Development team has remained separated from the rest of Autodesk. They have very close personal commitment to the individual user. I have had the founders of Revit come to my office to get a better understanding of how I work. That's personal commitment! At the Zoogdesign forums, you will see many of the Revit staff regularly contributing. They rely on our communications with them through the forums and other means to continually improve the product.
2004-03-15 09:30 AM
Scott wrote:You know that this explanation is the first time I understand what a Revit family more or less can do!Revit users can create their own library objects by using templates designed for this purpose. 3D modelling and 2D graphics (if desired) can be combined together with parametric dimensions and other parameters (e.g. materials for rendering). You don't need any programming knowledge, though I often have to spend several hours with new users before they get the hang of creating these new objects. It's not hard: it's just a completely new experience for most people. These objects are fully parametric and can employ formulae, e.g. width = 2 x height, or window top angle = arctan (roof slope). Arrays can be built into the object, so that a louvered grille can automatically add louvers as needed if the grille object gets taller. Families are major benefit of Revit over AC.For information only, not intended to be a "look why software x is better than y":
Revit 6.1 was just released this past week. Now the Family Editor (not a separate program, internal to Revit) has even more power. The developers added Conditional Formula Parameters and Parametric Display options. The first tool allows the user to assign conditional IF/THEN AND/OR formulas to a Revit object, through simple dialog box interface. The forumulas are exactly like MS Excel "=IF (VARIABLE, IF TRUE, IF FALSE" so they are familiar to most. Example: a window can be conditional, if it's less than 2'-0" wide, it has no muntins, otherwise is has muntins. Conditional formulas can be nested together as well. Parametric display allows ON/Off control of parts of an object. One Family can now contain basically unlimited options. A door family, for example, can have different panel configurations, hardware, trim, etc., which can be turned on and off from within the model. As these changes are made, the entire model updates instant, plans, sections, elevations, 3D, schedules, sheets.
