ā2013-04-21
11:21 AM
ā2023-05-24
12:48 PM
Rubia Torres
ā2013-04-21 05:17 PM
ā2013-04-21 05:33 PM
ā2013-04-21 05:37 PM
ā2013-04-21 06:48 PM
Matthew wrote:as far as I know I can't explode them into lines. what it works is line consolidation, but this is way too much clicks and operations.
If you explode the polylines they become lines.
OTOH it is vanishingly rare that I have run into situations where I could not get the walls to intersect properly. For those few occasions the patch tool did the trick just fine.
ā2013-04-21 10:17 PM
mzex wrote:I stand corrected. I'm not sure if my memory is faulty or perhaps it has changed. But really, if you are doing this so often that the extra clicks are a problem you might do well to review your wall joining techniques.Matthew wrote:as far as I know I can't explode them into lines. what it works is line consolidation, but this is way too much clicks and operations.
ā2013-04-21 11:29 PM
ā2013-04-22 08:24 AM
ā2013-04-22 11:50 AM
Matthew wrote:sometime some of walls are not connected well and that can be corrected, but most of the times I don't have time to search for solution so I go into worksheet to correct one wall connection and that is done in few seconds (if walls are exploded into lines)while trying to connect walls would consume much more time.mzex wrote:I stand corrected. I'm not sure if my memory is faulty or perhaps it has changed. But really, if you are doing this so often that the extra clicks are a problem you might do well to review your wall joining techniques.Matthew wrote:as far as I know I can't explode them into lines. what it works is line consolidation, but this is way too much clicks and operations.
