Why is this report Showing up?
Since installing Archicad 18, any time I change views to 3-D I get the attached report. How do I make it go away?
David Maudlin
Cheikh T Sylla:
There is a problem with the 3D Script in the library part m_Rail Balustrade.gsm, which could be an Object, or could be a macro called by an object (from the name it seems like it would be part of a stair). You will need to narrow down which Object is causing the error (by using the Marquee Tool or Layers) to find the problematic Object, then alter its parameters to fix the issue.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
Thanks for the suggestion. When I deleted the stair the problem stopped. So I will now figure out the setting that is causing the problem. I will also add my signature.
David Maudlin
Cheikh:
Based on the name of the macro, I would look at the stair's railing parameters.
Thanks for adding the signature.
David
