Why schedule is showing different result
Hello
I have drawn a double side plasterd wall.
which is 3000 length and 3000 height
in schedule, why brick area showing 1.2 m2 and Stuco white fine 18.3
plz explain.
1 REPLY 1
DGSketcher
Legend
You haven't indicated the thickness / width of the wall, but from. the numbers it looks like it is reporting the base area of the brickwork 3m long x 0.4m wide = 1.2m2 and the stucco may be oversize to include the exposed edges. See if this explains...
https://helpcenter.graphisoft.com/user-guide/128485/
