vfrontiers
Why the *&^%^ don't my tif's print...
I am tired of scanning design sketches and importing into models and layouts only to have them NOT PRINT...
Sorry for the outburst, but something has to give... I can't keep wasting my time with this.
I can see the scan fine on plan... just prints NOTHING where a scan should be on paper.
Tried PDF, tiff (it's b/w).... Reduced file sizes.. still no print.
Help!
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
12 Replies 12
I had that problem. I converted the TIF to a PDF and then removed the tif and replaced it w/ the PDF on the layout. It worked.
Rick Thompson
Well, I use tiffs on my cover sheets each and every time I print, and have for years. I have never had that issue. Windows thing? I drag and drop the tiff image on the layout, and size. They always have printed.. well actually plotted.
Big help.. huh
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
vfrontiers
5000x10000 pixels?
It must have something to do with that old 4048 pixel limitation.
Duane
Visual Frontiers
AC3.14 - AC29
Link
From what I remember, that 4048 pixel limitation only applied to the size of renderings ArchiCAD (9) could output. It was later lifted to 32767 pixels by 32767 pixels.
Link.
Duane
Wild guess.
Could it be that you have layers that are not transferring over?
Since tiffs can have layers like psd's, maybe flattening files first?
Bier
vfrontiers
Don't think so.... All is visible on screen... I am pretty sure they are FLATTENED tiffs...
Duane
Visual Frontiers
AC3.14 - AC29
Duane
Sounds like a similar issue we had with tiff's except ours were dropping out when printing PDF's! Have you tried turning OFF the transparency?
Have you tried it with image formats other than TIFF?
Rick Thompson
It's been a while, but I did once have problems with tiffs not printing until I preformed a "bring to front", but I think that only happened when the tiffs were on a master. I have not had that happen in a while.. maybe since AC10, but it might be worth a try. The tiffs were visible, but did not print until I did that. My tiffs are small.
I know it makes no sense, but what can I say.
Rick Thompson
Mac Sonoma AC 26
