Winder stair in 3D - bug?
Surely this is a bug. I have used the stair tool to create a stair with a winder at the top and bottom. It looks perfectly fine in plan. But in 3D it somehow skews the underside.
Anyway I can fix this? I'm on ARCHICAD 20.
Thanks,
Ben
alemanda
I got the same issue in AC19
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores) - 32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 2560x1440
Thanks Alemanda.
Does anyone know if this is a confirmed bug up to ARCHICAD 20?
