‎2008-08-26
10:50 AM
‎2023-05-25
06:10 PM
Rubia Torres
‎2008-08-26 10:50 AM
‎2008-08-26 10:51 AM
‎2008-08-26 06:06 PM
‎2008-08-26 07:38 PM
‎2008-08-26 10:21 PM
‎2008-08-27 12:50 AM
‎2008-08-27 01:07 AM
Ruben wrote:Yes you can do it that way if you wanted.....but there is something more intuitive to achieve what you want......it involves "wallhole" ....if I'm not mistaken one or more of the links I gave you suggest this technique....
Thanks for the links but custom doors I already did and it was quite simple.
My problem is still on the openings.
Can I make a object as the negative of the opening and then remove from the wall the piece with Solid Elements?
‎2008-08-27 01:14 AM
Ruben wrote:The advice in the following post may be applicable in this case too:
I need help in the modeling of windows and doors of a XVII century building in Mozambique Island.
Im attaching some pictures so you can have a better view of the challenge.
‎2008-08-27 01:15 AM
