Haneef Tayob
Window drawing suggestions required
I would really appreciate it if users could suggest the best and quickest way I should be drawing the following type of windows (see attached image) in my building model.
One option I require is for a window with 3 divisions. I want to be able to vary which of the 3 divisions are openable. Sometimes I might want there to be 4 divisions.
The other option I require is for a window with a top and bottom row of windows where I want to choose which are openable.
Thanks
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
Haneef,
The quickest way is with CadImage D&W Builder. I use it almost exclusively now because I can do just about any window or door I can think of. Some cost on the front end but a lot less frustration afterwards.
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
I agree, i haven't used an 'ArchiCAD window' in at least 2 years, they seem very counter-intuitive, unlike the Cadimage add-on which works brilliantly, and is so easy to edit and do the kind of things you described,
