Josephi7
Window reveal skin turns don't show on 3D
Greetings, I'm using the reveal option on Windows to turn the insolation and finishing of the wall inside the window space. But in 3D it doesn't appear the same as in plan.
How do I make it appear in 3D?
(I am using version 25 on Windows 11)
Plan view where the insolation turn inside
This image in core only view shows how the insolation didn't turn on 3d
Thank you
Operating system used: Windows 25
1 Reply 1
You can use the Search function at the top of this page to look for posts related to this... and find dozens of posts over many years.  This is a long-wishes for feature that has yet to be implemented.  It's very unfortunate as this affects projects of every size and yet it is not on the roadmap.  You'll have to use one of the workarounds in those old posts to get the 3D and Section views to appear properly.
