Window
Hi there
I draw a curved wall with complex profile,but I cant draw window in this wall what should I do?
5 REPLIES 5
Dwight
Do you mean:
-- that you can't see a window placed in the wall in plan view?
-- that the window floats way from the wall surface?
How complex is the wall?
Can you show it, please?
And some complex profiles don't cope well will windows....
Dwight Atkinson
I draw these walls with complex profile,I cant draw window at all,here is the pic
Dwight
Your sketch is too complex for me to understand.
Pick just one complex profile wall as an example.
Post the profile shape.
Then we will see.
Dwight Atkinson
Hi
here is my wall that I darw it with complex profile,but I cant draw window for it plz help me
Dwight
Fine. There's your problem: you want to put a window in the END of the wall, not the FACE.
When you define the complex profile, you will define the end rather than the faces.
Figure out a way to make four faces for each shape. Then the windows will insert.
Dwight Atkinson
