sarahric
Windows & Doors in Elevation
I have noticed recently that in elevations and sections my doors and windows aren't showing the edge of the frame/wall.
I've attached a pdf to show what I mean.
I have been through all settings - views, renovation filters, object attributes, but can't find the solution
ArchiCAD 18/Windows 7/16GB Memory/i5 3.2GHz Processor/NVIDIA GeForce GT 610
If you look closely at the first image there are little white gaps on the guidelines where your opening lines would be.
I would suspect they are being drawn with a white pen.
Go into the opening settings to see if you can change it.
sarahric
Thanks Barry,
I had been through every pen setting I could find in the opening settings.
Turns out it was the uncut pen setting in the wall.
