Wish or tip for clean vector hatch ?
hello all,
Please find attached a pdf file method, which describes how to do clean continuous vector hatch pattern on Archicad ( wrapping ). It is the equivalent of a photoshop s command filter, ( which we don't remember the name !), which allows you to perform continuous pattern.If this can help many users we would be happy
It would be wonderful to find this kind of utility in future release. Now between what we wish and what we really find in it,
10 REPLIES 10
Nice tip.
Thanks Masse.
lec
vistasp
Very useful, thank you!
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
This file has been downloaded over 68 times ... and only 2 comments, now I doubt his side understandable
Thank you Vistasp and Lec1212 for your support
Mats_Knutsson
Great tutorial!
Thanks!
AC 25 SWE Full
JaredBanks
Mentor
Great tessellation lesson!
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
Link
Handy little tip for those who need to create their own tesselated Symbol Fills.
The crux of the solution is to make suitable alignments in step 5, which will be invariably tricky depending on the amount of lines are available to connect, and their position.
And I guess that apart from removing the construction lines, you don't even really need step 6?
Still, a good tip and one that I'm sure will be copied into the Tips & Tricks section.
Link.
Link.
Yes Link you're absolutely right !
Here is the same file updated in six step
Thank you for your comment
Peter Bennison
Yes, great tip, thank you. Is Massa the same person as Eric ( I am what we call a lurking member of fc-cadlink) ?
Salut, Peter
Archicad 21 FR MacBook 2.5 Ghz Intel Core i7 16Mo RAM MacOS Sierra
No Peter .Masse is Masse . . Eric is a great old friend and fondator of the fc cadlink site
