Zone Name character limit
Is there a way to to input more than 31 characters for a Zone name?
4 Replies 4
Hello,
Seems to be limited by default, see
http://helpcenter.graphisoft.com/guides/gdl-guide-for-archicad-18/chapter-12-miscellaneous/fix-named...
ROOM_NAME
Type: string
Possible length: max. 31 characters
Returns the name (e.g. 'Living Room') of the Zone. The default value set in the Zone Stamp Library Part is overridden by the value set in the Zone Settings Dialog.
What does this mean? Can I change these settting?
Hello,
I am afraid the zone name text field does not
accept more characters than 31.
As a workround you could use an autotext -> write
the long zone name to the autotext table and use
<autotextname> format in the zone name text field.
Hope this helps.
Jochen Suehlo
I think, this topic we had some times ago.
If you use the User Interface for the input of the ROOM_NAME,
you are able to put in more than 31 characters,
which will be shown in 2D as well.
(ArchiCAD 16, maybe earlier)
Jochen Suehlo . AC12-29 . MAC OSX 14.4 . WIN11
GDL object creation: b-prisma.de
