Zones disappear in 3D
I have newly started file - it's just an architerra- created site mesh with a few walls and architerra building objects. I then added a manually defined zone. If I select the zone and then choose 'show selection in 3D' it appears as expected. However, if I then select 'show all in 3d' everything else appears but the zone disappears.
I've checked heights, and turned other objects off to make sure that it wasn't hidden by something else and have tried zones on different stories with the same result.
any ideas?
thanks.
3 Replies 3
Dennis Lee
Try typing in Ctrl - Alt - A , and see if Zones are selected.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Dwight
"Filter Elements in 3D"
by default Archicad DOES NOT image the zones in 3d but it can be enabled.
Dwight Atkinson
Thank you!!!! It's always something simple. I knew I had viewed zones in 3d before but must have forgotten the filter command.
