We value your input!
Zones in Elevation/Section
is it possible to view zones in elevation/section using the section elevation markers?
4 REPLIES 4
no, why do want do that?
I agree, it is very desirable to see zone data in sections.
Erika Epstein
Other than displaying the name of the zone, it could be helpful if you use zones for massing studies at the beginning of projects. That said, because they don't show in section and are not as easily to play with as slabs for example, most use the slab tool at this stage.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Zones do not show in sections and elevations, but in 3D documents they do. You might consider using 3D documents, you can cut the model and show the sections. You can choose the axonometric view or perspective.
And then you can add 2D information.
HTH
