2007-10-23 03:27 PM
2007-10-23 07:52 PM
2007-10-23 08:37 PM
2007-10-23 09:01 PM
Pete wrote:If you select the zone and go to settings, you can change the zone polygon from Net to Gross (upper right corner of dialogue box below name info) and the outline/hotspots will move to the gross outline.
Yep, same deal. My net is a lot less than gross, but only in some zones. I experimented with a plain square on the same story of the same file using the same zone stamp and settings. The square worked correctly (unless I put another room inside it, but that's another issue).
So, I think the problem is the boundary to reference line, but since I cant see that boundary, I can't tell where it is.
2007-10-23 09:21 PM
2007-10-23 09:32 PM
