Zones without surface
Is it possible to create a zone without its surface indicated (i am only interrested in labelling the floor and walls material)??
I assume you mean that the zone fill is showing up in a plan view? Look at your Model View Options - you can control zone appearance there.
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Thank for your reply, but i still can't find what i am looking for in the options view model.
I am looking for the following :
For each zone created, there is in plan view a label with the name of the zone, its surface and as optional parameters the material name of the walls, the florr, etc... I would like to show in this label the name and the materials of the wall and the floor, but not the surface.
Is it possible?
ok i've found where zones are parametrable : it is in 'elements attibutes'
