Zones
How can i adjust the Zones without using the wall to wall tool? Lets say i just wanted to choose a small area in a room, how can i grab the corners of my zone stamp and add, subtract, or stretch....? Is there a way to turn on hotspots for the zone tool? I cant seem to find it?
12 Replies 12
Did you check and make sure you are using an 11 zone and it didnt get linked back to a 10 zone maybe?
well our latest version is 10, not 11. How would I check that anyway?
Hmmm. If you are using 10 then i believe will have to set your Model View Option - Zone Background - Category Color. I think that is what I use to be able to change the zone once I placed it in. Also you can try changing the whole Model View to the predefined Presentation View. One other thing when you created it did you do the Manual or the Inner Edge? If you did the Inner Edge then all you really need to do is to Update the Zone - Design menu - Update Zone - Update all zones. If you did it as a Manual then try changing the Model View Option.
