Zoom Setting in Elevations
Brett Brown
Hi all, Can someone tell me why in AC 11 the zoom setting in elevations don't stick after rebuild. When I double click the elevation in view map the elevation appears instantly how I saved it, at the right zoom, then it rebuilds and when finished, it has zoomed right out. Has something changed in AC 11 from the way it worked in AC 10? Plan views work ok, its only Sections & Elevations.
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
David Maudlin
Brett:
Select the view in the View Map, then click on the "Settings..." button at the bottom of the palette. In the View Settings dialog box, in the 2D Only settings, check the setting for Zooming.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Link
In the Imaging and Calculation area of your Work Environment, check that the 'Keep zoomed detail on Rebuild from Model' is checked.
Link.
Brett Brown
Thanks for that Link.
