DennisG
Can't Print PDF inserted into PLN file
Interesting anomoly, am wondering if anyone else has encountered this?
I inserted a PDF into the PLN file, plan view, using "File-External Content-Place External Drawing" command.
Once the PDF was inserted I drew a number of lines over it.
When I went to print the results, I found that all that printed was the lines that I had drawn.
The only way I could print an accurate depiction of what I'd created was to click on the inserted PDF so that it was highlighted, and then print to PDF Factory, creating another PDF. I was then able to print a hard copy from PDF Factory.
The same tactic did not work when I tried printing to the Canon printer.
Thankfully I was able to print a hard copy, but not until after one hour of mucking about.
Has anyone else experienced this? Did I do something wrong? Is there an unspoken rule about attempting to print inserted PDFs?
Thanks,
Dennis
Dennis Glynn AIA
ArchiCAD-64 23 3003 USA FULL
x64 Clone PC w/Intel(R) Core i7-4790 CPU @ 3.60GHz, 3601 Mhz, 4 Cores, 8 Logical Processors
NVIDIA Quadro K620
16.00 GB RAM
Win 10 Pro x64 based PC
8 Replies 8
We had the same problem in the office but I'm also hoping for a solution
Chazz
Yep. Particularly with complex PDF's. I've heard elsewhere that having the PDF's cropped can also contribute to them not printing . Interestingly, in my case the failure was device dependent: I could get it to print (never tried a PLOT) to a n HP 500 but it would fail every time to a Ricoh. Installed memory could be a factor. Whatever the cause, the failure mode is lousy: you never get feedback on what the problem is.
Nattering nabob of negativism
Rakela Raul
http://www.archicadwiki.com/Bugs/Drawings_with_images_do_not_print
anything to do with this ?
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
I have had mixed experiences with Ricoh and very bad ones with Kyocera. The Kyocera problems also came up with AutoCAD so I suspect a lot of the issues relate to the underlying differences between CAD/technical drawing and mainstream text, image and illustration standards.
Chazz
I doubt it. This Wiki post relates to rasters (Jpg, and PNG) and the PDF problem (at least in my case) had to do with pure vector PDFs. But it is possible that embedded rasters in PDFs could be a factor for some. It's a tricky issue.
Chazz wrote:
...It's a tricky issue.
Printing always has been. At least it's gotten lots better over the years. Presumably it will get sorted out as PDF becomes more settled as the universal standard (somehow I find it hard to believe that Autodesk really has a chance to make DWF a widespread standard).
DennisG
Good point - this was a cropped PDF - not large or complex at all.
Could be, though my machine has plenty.
Agree.
Thanks much for the responses - glad (and concerned) to hear I'm not the only one experiencing this.
Dennis
Dennis Glynn AIA
NVIDIA Quadro K620
16.00 GB RAM
Chazz
Matthew wrote:
Printing always has been [tricky]. At least it's gotten lots better over the years. Presumably it will get sorted out as PDF becomes more settled as the universal standard (somehow I find it hard to believe that Autodesk really has a chance to make DWF a widespread standard).
Yes, but despite that I find myself occasionally harkening back fondly to the halcyon days when men were men and plotters CAME with HPGL/2 cards and we always plotted, never printed. I still see issues with scale creep and font weirdness when using PDF as an exchange/output format.
As for DWF, it certainly has impressive speed but, yes, I think Autodesk has lost that one. I'm just not sure they have lost it to Adobe. Silverlight is very impressive and as much as I would hate to see Microsoft dominate this market, some competition would be good.
Are we OT yet?
