‎2007-06-29 06:38 AM
‎2007-06-29 10:43 AM
‎2007-06-29 06:13 PM
‎2007-06-29 06:47 PM
‎2007-06-29 07:39 PM
Chazz wrote:I have had mixed experiences with Ricoh and very bad ones with Kyocera. The Kyocera problems also came up with AutoCAD so I suspect a lot of the issues relate to the underlying differences between CAD/technical drawing and mainstream text, image and illustration standards.
I could get it to print (never tried a PLOT) to a n HP 500 but it would fail every time to a Ricoh.
‎2007-06-29 08:02 PM
Rakela wrote:I doubt it. This Wiki post relates to rasters (Jpg, and PNG) and the PDF problem (at least in my case) had to do with pure vector PDFs. But it is possible that embedded rasters in PDFs could be a factor for some. It's a tricky issue.http://www.archicadwiki.com/Bugs/Drawings_with_images_do_not_print
anything to do with this ?
‎2007-06-29 08:13 PM
Chazz wrote:Printing always has been. At least it's gotten lots better over the years. Presumably it will get sorted out as PDF becomes more settled as the universal standard (somehow I find it hard to believe that Autodesk really has a chance to make DWF a widespread standard).
...It's a tricky issue.
‎2007-06-29 08:45 PM
Chazz wrote:Good point - this was a cropped PDF - not large or complex at all.
Yep. Particularly with complex PDF's. I've heard elsewhere that having the PDF's cropped can also contribute to them not printing .
Chazz wrote:Could be, though my machine has plenty.
Installed memory could be a factor.
Chazz wrote:Agree.
Whatever the cause, the failure mode is lousy: you never get feedback on what the problem is.
Matthew wrote:Yes, but despite that I find myself occasionally harkening back fondly to the halcyon days when men were men and plotters CAME with HPGL/2 cards and we always plotted, never printed. I still see issues with scale creep and font weirdness when using PDF as an exchange/output format.
Printing always has been [tricky]. At least it's gotten lots better over the years. Presumably it will get sorted out as PDF becomes more settled as the universal standard (somehow I find it hard to believe that Autodesk really has a chance to make DWF a widespread standard).
