2009-01-08
08:31 PM
2023-05-25
04:56 PM
Rubia Torres
2009-01-08 08:49 PM
2009-01-08 08:57 PM
2009-01-08 09:06 PM
2009-01-08 09:22 PM
2009-01-08 10:03 PM
zilberdik wrote:StairMaker is built into ArchiCAD and is probably what you are using. ArchiCAD also comes with some parts in the library that can be placed without the use of the built-in tools. The library parts are still accessed through the stair tool so this might be a little confusing. Archistair is a commercial add-on from Cigraph and Stair Builder is one from Cadimage.
whats the difference between library parts, StairMaker, Archistair, Stair Builder and what of all these is the "internal" built in way to create stairs
i mean what am i using right now ? (:
2009-01-09 10:23 AM
Erika wrote:once you've created the stair in stair-maker (i assume this is how you're making the stair?) and placed it on your floor as discribed in the other posts here, the setting Erika refers to is accessed in the stair object settings - not within stairmaker.
Look for the SHOW ON STORIES settings and choose the option that will show the stairs as you want. You may want to place it on the middle floor and then choose SHOW ON ONE STORY UP AND DOWN.
2009-01-10 05:06 PM
