ac17 zone identifier 2 17 & NO custom settings??!!
hi,
the videos & help file talk about ac17 zone identifier 2 17 custom settings as a new feature but it is grayed out?
any thoughts on that
thanks,
joseph
21 Replies 21
vfrontiers
Check and make sure your Zone's RENOVATION STATUS matches your WALL's Reno status... There are instances where EXISTING zones cannot be placed in NEW construction...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Thank you!! That was it. The walls were all proposed but existing was still the default when I selected the zone tool. It worked when I created new, temp walls because they were also being created with existing as default. And when I got the weird error followed by zones incorporating the area of a couple walls, that was because those walls were (incorrectly) set to existing.
Now the zone stamp isn;t showing up, but I'm sure that will be solvable....
Thanks again, this made me nuts last night
UPDATE: visibility was just set to off by the model view I was using, all is good now
