Dave Seabury
Elements showing in plan view and no where else
I am updating some base plates on some steel columns, the new base plate
(a slab) shows in plan view but will not show in the detail drawing or any other drawing. If I select the base and "show selection in 3D", nothing.
I've check the renovation status, layer setting and they are all correct.
If I move it to the Archicad Layer, it shows up.
Anyone have any ideas?
Thanks in advance,
David
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
3 Replies 3
NCornia
Graphisoft Alumni
Graphisoft Alumni
I wonder if it is interacting with another element. Have you checked the Layer Intersection Group Number of the layer the base plate is on? Try changing the number in the layer settings to see if the base plate appears.
HTH
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Dave Seabury
You nailed it! Thanks. I keep forgetting about the layer intersection, that's the second time I've done that. Maybe I'll remember from now on. Thanks again.
David
NCornia
Graphisoft Alumni
Graphisoft Alumni
That's great. Glad to help.
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
