adjust areas = update zone
i am using the zone tool to calculate areas.....
i have placed zones and am trying to edit them
when i adjust the perimeter of the zone, the area does not change
the measured gross area but does not show on the floor plan
the measured net area will apear on the floor plan.... but that number does not change
in the zone stamp pull down of the settings
'show area' box is on
but, again it shows only the net area
how to show adjustments in the stamp on the floor plan?
4 Replies 4
__archiben
one of the more shocking features of the zone tool - you need to use the 'Update Zones...' command for changes to take effect. some zone stamps are written to update themselves, but area lists generated in the interactive scheduler still need the 'update zones' command to be invoked before the schedule will update.
~/archiben
b e n _ f r o s t
thanks
that was a bit frustrating
i found the solution 5 min after i posted
go figure
thanks for your speedy response
hope this will help anyone else who has this problem
Stephen Dolbee
I use the fill tool for area take-offs. Much less frustating than zones.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
stefan
Beware that the "Update Zones" command only works for the current story!
You have to repeat it for the other stories.
Archicad-user since 1998
my Archicad Book
