animating objects in walk through
I am tryin to create a walk through using archicad 11. I have manged to to bring in day light change animations and animating doors to open and close using art*lantis. How ever the problem i have now is to get cars and people to move, with the inclusion of wheels in motion. is there any way of achieving this is archicad. Or something similar.
Maya and 3ds max were obvious choices of a few people i asked around but i am not too happy with the quality of the output of both, as in the renderings are too animated and the reflections nowhere close to archicad's rendered images.
Help!!!
P.S.
Maya and 3ds max are like chineese and japanese to me...
2 Replies 2
Thomas Holm
Artlantis Studio would let you do it.
Surely you are joking here, as Maya, 3ds, and Cinema 4D are all greatly superior to ArchiCAD for such images, and of course, all allow the animations you are asking about.
As Thomas says, Artlantis Studio is the easiest solution for adding animated elements to an ArchiCAD model. But, it is not without its own peculiarities. For example, getting tire wheels to spin at an appropriate rate for the forward motion is not at all easy. Animating ArchiCAD doors requires converting them to Artlantis objects and then animating the object - and at that point, getting the door to rotate at the hinge side and not the center is a challenge. Etc.
Within ArchiCAD, people used to talk here about using the Alfaville cars (for example) in animated flythroughs - there are animated people, etc as well:
http://www.objectsonline.com/customer/product.php?productid=121424&cat=0&page=1
I haven't seen these mentioned in quite a few years though, so don't know if anyone is still using them successfully in current versions of AC?
Because they rely on GDL animation, those objects can be animated in ArchiCAD flythroughs, but none of their animation 'intelligence' would be available externally - in Artlantis or whatever.
HTH,
