Cutting a profile out of wall then tilting wall?
I want to cut out a complex profile in a wall, using Chamfers and Angled lines. I then want to tilt the wall. What is the best possible way to do this? Cheers
5 Replies 5
Dwight
You would create a tilted wall first, then place a special window opening you create by making a slab you give the ID "wallhole" to, saving its 3D top view as a window.
Wacky, I know.
Dwight Atkinson
Cheers Dwight,
So i make the profile using the line tool then i slab it and save it as a top view. Save it as a window in objects folder! is that correct??
Dwight
almost.
you will name the slab "wallhole" in its ID box - attached image - prior to the 3D view
Dwight Atkinson
Thanks for your help Dwight, hopefully i can call on you again in the near future.
Dwight
Were you to come on a Sunday, i will serve tea and cucumber sandwiches.
Dwight Atkinson
